It is currently Thu Mar 21, 2019 6:16 am
Reply to topic  [ 5 posts ]
Questions when stripping an IX.
pt n00b
User avatar
BMW: 1989 325ix
Post Questions when stripping an IX.
Boys & Girls,
So my daily driver IX is parked while I work on removing some much needed parts from a donor IX car.
My question is after the usual stripping of drive-train, interior, wiring, good body parts, etc.. is there anything I should consider removing from the shell itself?
I'm sure a buttload of shell pieces are NLA, so before I chop up the remaining body, thought I'd ask for your thought!
Thanks
Mon Jan 01, 2018 8:16 pm
User avatar
BMW: 2008 335xi
2003 M3
Post Re: Questions when stripping an IX.
Did you mean xi?
You didn't mention the year/model/body style. I have a 2008 335xi sedan. It wasn't equipped with an oil cooler and with the 2 turbo N54 and JB4, the oil temp started getting quite high in the summer. I've since retrofitted an aftermarket oil cooler and it runs about 110C all day long. :)
If you're in the same boat, strip off the oil cooler, oil cooler support, threaded support nut insert, rad support with bolts, oil lines and brackets, oil filter housing, fender liner, air scoop and open grill.
The only other problem I've had to date is a burned out angel eye bulb. This is going to cost $75 at a dealer with a pita diy install.
_________________
Rick
Mon Jan 01, 2018 8:55 pm
User avatar
BMW: 73 2002, 88 iX, 88M3
No, he is talking about his e30:
BMW: 1989 325ix
Seems like you have it pretty much covered: drive-train, interior, wiring, good body parts, etc
Make sure you take the front axles, they are very expensive to replace.
Don
Tue Jan 02, 2018 1:18 pm
pt n00b
User avatar
BMW: 1989 325ix
Ya, sorry Rick I was talking about my e30..
Thanks Don: I've read about those front axles...wow!!
Tue Jan 02, 2018 7:47 pm
BMW: 2003 325xi
Grab the steering rack. I believe those are ix specific.
Also the brake booster, people use it for some engine swaps. Could be worth something.
Sun Jan 14, 2018 11:35 am
Users browsing this forum: No registered users and 2 guests
