It is currently Mon Jul 23, 2018 11:49 am
Reply to topic  [ 6 posts ]
Power steering failure
Author Message
User avatar
BMW: E36 328is
Post Power steering failure
Ok guys so i am going through power steering pumps like crazy and cannot figure out why. I have a 96 328is with an m3 steering rack. Would i need to se an m3 power steering pump and what else could be causing the failures?????? I am at my wit ends and will just park this car forever.
_________________
m52 goodness
Wed Sep 27, 2017 3:00 pm
Profile
User avatar
BMW: 2002 M3
Post Re: Power steering failure
What are the symptoms? I had PS problems on my 97 M3. Eventually replaced the rack and pump. I think I did pump first and it didn't help so then I did the rack.
Wouldn't have thought rack would fail.
Sat Sep 30, 2017 8:34 pm
Profile
User avatar
BMW: E36 328is
Ive got massive amounts of whine from the pump and no hard to steer as well. It seems like it not cycling the fluid through.
_________________
m52 goodness
Sun Oct 01, 2017 11:35 pm
Profile
User avatar
BMW: 2002 M3
If you have replaced the pump and hoses are not crimped then the rack is only other thing it can be. I know mine started out really tough to turn and I did pump and it didn't help so I did rack and that fixed it.
Then on my E46 had same issue so I changed the rack first and it turned out that the pump input shaft was sheared off. (common for that model)
Tue Oct 03, 2017 7:03 pm
Profile
User avatar
BMW: E36 328is
I wonder if i can rebuild the rack, it is an m3 rack so not very common to find these not in an m3.
_________________
m52 goodness
Wed Oct 04, 2017 1:35 pm
Profile
User avatar
BMW: 2002 M3
Order one from rack doctor. Much less than buying new. I have a couple of old ones that I was always going to rebuild but never got to it. I don't imagine they are difficult but buying rebuild seals would be the issue
Wed Oct 04, 2017 8:25 pm
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Jump to:
