It is currently Sat Jun 23, 2018 7:18 pm
Reply to topic  [ 5 posts ]
E36 M3 Ignition wiring help
Author Message
pt n00b
User avatar
BMW: 1998 m3 Sedan
Post E36 M3 Ignition wiring help
hi all - my heater blower motor wasn't working this week so I took some initiative and removed the plastic cover under the steering wheel and tried to locate the final stage unit to see if it was loose. Anyway - when I got the cover off, I didn't easily see the final stage unit so I decided to abort the job. When I was putting the plastic cover back on I shimmied some of the wires under the steering wheel. Now my car suddenly won't start. I am pretty sure I jigged a wire loose. My starter has always been super strong including today before I poked around with the wires.
Does anyone know of anyone who might come by and check it out at my place in SW Calgary for a fee?
I'm hoping its very minor and just a connection or something that I inadvertently loosened.
I'm not great at mechanical stuff...
thnx everyone for any ideas
pb888
Sat Feb 17, 2018 11:48 pm
Profile
pt n00b
User avatar
BMW: 1998 m3 Sedan
Post Re: E36 M3 Ignition wiring help
fascinating - found some info online on point. Problem resolved by replacing fuse #31. Key symptoms were no starter engagement and also the HVAC display was blank. Changed the fuse and perfect now.
Tue Feb 20, 2018 10:45 am
Profile
Online
User avatar
BMW: 2008 335xi
2003 M3
It's good to hear that you fixed the problem. You must be relieved. That reinforces the troubleshooting practice of checking the simple stuff first.
It's amazing what you can find with google and the internet.
_________________
Rick
Tue Feb 20, 2018 12:06 pm
Profile
BMW: 2003 E46 M3
I was going to suggest the Transponder Ring that goes around the key barrel, its a plastic ring with a coil in it that relays info from the chip in the key to the EWS module under the steering column.. they tend to burn out along with the chip in the key and can cause similar issues..
Glad it was a cheap fix in the end
Mon Mar 05, 2018 8:30 pm
Profile
pt n00b
User avatar
BMW: 1998 m3 Sedan
yes agree - troubleshooting things I can do on my own with a bit of info from googling saved me stress and some cash for sure!
Mon May 28, 2018 5:20 pm
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Jump to:
