It is currently Wed Jan 16, 2019 11:12 pm
Reply to topic  [ 47 posts ]  Go to page Previous  1, 2
e30mclow's latest e30 Project
BMW: 2002 M3
Post Re: e30mclow's latest e30 Project
There will be fewer and fewer low cost LS engine and trans combos as time goes on. You have older Camaros, CTSV and Pontiac G8 (auto only). I would jump on the 3500. Now if it is a 99 it will be an LS1 350 hp. You could also get a later truck engine with alum block but then have to buy trans etc separate.
Sun Jan 14, 2018 10:47 pm
BMW: Stage III Audi S4
Unfortunately I missed out on that package.
There's a corvette breakers yard that'll ship me something from Charlotte.
Right now they have an 85k mile 5.7 LS1 for $2,500 (no box).
I'll keep reading up on what the best option is for an e30 swap.
Qualicas - As a guy that's now done what, 3 LS swaps? What did you find to be the best option in terms of $/Weight/Power?
Mon Jan 15, 2018 12:04 pm
BMW: 2003 E46 M3
When i done my S50B30 Swap, i felt that 300BHP was just about right for the e30 Chassis it broke away at highway speeds when overtaking in 4th with the foot down, i had crapy/worn tires on the back which was most of the problem on a damp road,
Snappy power but drivable, i recon if i had anymore power it would be hard to put down on the road
Mon Jan 15, 2018 10:46 pm
BMW: 2002 M3
Actually, just one LS swap. I bought everything new and custom. Now I would just buy an LS with alum block from any GM truck. Most common will be the 5.3 litre. Buy that, change cam and intake and you have easy 400hp at crank. Probably check car-part.com and buy ex Canada. Local auto wreckers have 6.2 and 5.3 engines for $2000+. Then check for T56 trans or buy new for $3000.
No matter which way you go, it will be a lot of money but building it is fun and driving even more fun. Not cost effective EVER to modify any car.
I have rebuilt a number of BMW cars and engines etc though.
Tue Jan 16, 2018 3:00 pm
Serious kit arrived tonight.
The chassis will flex before any of this business.
The seat search continues. Having been beaten to a set of m3 seats, I've found these Recaros 3HRs away that I may take a chance on.
Tue Jan 23, 2018 7:35 pm
Picked up the recaros this morning, after a lot of driving.
In case anyone thinks I'm being JDM tacky, this is as close as I'll ever get to the feel of the Holy Grail - the e30 M3 Sport Evolution
Managed to make it home from Virginia with enough time to install the rear sway bar. The install ran into darkness, so I'll post photos tomorrow as I install the front bar.
Brackets for the seats should be here on the 5th or so.
Sat Jan 27, 2018 8:38 pm
Got the ARBs in last weekend, now it is finally on to fixing the interior!
As a reminder:
What's to come:
Should be all swapped out on Saturday, before my Recaro brackets arrive on Tuesday.
Thu Feb 01, 2018 8:34 pm
Sat Feb 03, 2018 4:31 pm
BMW: 2003 E46 M3
Great Job Ger. looks Class
Sun Feb 04, 2018 11:46 am
BMW: 2003 E46 M3
BMW: 2010 328i
i like the red interior!
Sun Feb 04, 2018 9:36 pm
Wet sanded the car to try and find decent paint.
Eventually got the car to where it is far more presentable.
In more exciting news, I test drove a donor car yesterday.
I've been humming and hawing as to whether I make a terrible decision and do a swap on it, when a promising donor popped up. 2 black lines snaking down the road at the top of 3rd....it was actually frightening as I've not been in a fast car in quite a while.
I'm taking a few days to think about it, but I know me, and know I'll make a terrible decision and blow money that's needed for far more important things.
Anyway.
Single Turbo 1JZ non-vvti running around the 450hp mark.
6 speed Nissan 350z gearbox
650lb/ft Spec clutch
currently sitting in a tube fronted Lexus sc300 (Soarer).
A bad decision? Brakes will never be good enough.
Servo would need to be shifted closer to the fuse box and the sledge would need to be taken to the tunnel.
Sun Feb 25, 2018 4:37 pm
BMW: 2006 M coupe
Nice thread - thanks for keeping this site alive!
Mon Feb 26, 2018 8:51 pm
It looks to have been pretty quiet around here vs 4-5 years ago alright.
I'll keep things up to date on here as I go
Tue Feb 27, 2018 6:26 am
I picked up the donor car last night, which was a 7hr round trip.
Can't wait to start ripping into it!
Wed Mar 07, 2018 7:53 am
Started Auto-X shortly after getting the JZ, which has turned into an addiction lol
I hit the first few outings on my dodgy 2nd hand 8-10yr old tires, which resulted in lots of this sort of action
Sideways-ness
https://youtu.be/wPhmhYTmDTg
https://youtu.be/OOb6OEL7cWU
So I said F it and bought some cheapo wheels with extra beefy 225/50r16 sticky Kumhos
Having then removed the rear ARB, maxed out the front camber while increasing rear camber also, things have started coming together.
https://www.youtube.com/watch?v=FII6AQbALRE
Really enjoying pushing myself and the car before ruining it with a jap engine.
Mon Apr 23, 2018 7:45 pm
Sideways-ness
Looks like fun! Are those wheels Konigs? How hard/expensive was swapping that engine into the e30?
Tue Apr 24, 2018 8:14 am
I should have been clear - I've not swapped it yet.
I only bought the donor a couple of months ago and haven't touched it. The m20 is running so strong that I'm finding it hard to justify pulling it out right now.
Wheels are cheap XXR wheels that were only something like $60/ea. I only use them for autoX where I never get out of 2nd, so they'll do just fine.
Tue Apr 24, 2018 9:18 am
Wed Apr 25, 2018 1:08 pm
Stuff going on.
Bought a donor e30 for $200 which is allowing me to figure out the swap while still freeing up the white car for Auto-X.
Picked the donor up on a Tuesday and had the JZ in place by Thursday night. Engine mounts are on the way.
It took some massaging
I also swapped out the oil pan for a front sump layout, then everything dropped perfectly into place
I also stumbled upon a garage sale with a whole truck load of e30 parts. Lots of those handy bits and pieces one always needs.
Also installed a red carpet to get rid of the ugly stained beige.
On top of that, I also found some pieces at home in Ireland, such as euro lights, grilles and rear plate surround.
A few weeks ago I did the mother of all DIY alignments. Made a great difference and got everything so close that the alignment shop actually didn't need to adjust a single thing.
Current headache is gathering the dedication to try and line up the massive nissan transmission. It will take a lot of cutting/hammering while on my back on my driveway :(
I need to make some adjustments this week as I have 2 x events this weekend.
- grind some more space around where the steering column penetrates the bulkhead. The e46 rack changed the angle slightly, resulting in some binding.
- top up the trans fluid as there is a leak from the rear output seal. Not fixing it as it'll be coming out anyway.
- enjoy the thing :pimp:
Tue Jun 12, 2018 7:50 am
BMW: 1990 325i
Car looks great! I am loving what you've accomplished so far.
Just curious as to what brackets you used to mount your Recaros? There are some nice blue ones that I think would match my e30's interior well.
-Luke
Tue Aug 14, 2018 7:38 am
I used the brackets that made by Lee @ Massive Brakes. He's in Canada too, to the $ isn't crazy.
I've gotten a lot done in the last couple of months. I'll just dump the photos here.
The quickest way to check if the IC will fit behind the facelift valance:
Success!
With that confirmed, it was time to start preparing the white car
I then started cleaning and painting. I removed the AC to try and counter the additional weight of the new engine.
Rust treatment on the front panel
I then fixed up the portions of the wiring loom that I needed (lights, ABS and some other items)
I also marked up and trimmed some items back to make way for the IC hoses. It was useful having the mockup car, as I could test fit everything there.
I trimmed and rolled the edges to avoid sharp spots.
After that I removed and reinforced the front subframe before painting things up and applying some blingy DEI gold tape that I had left around.
Some marine window/door seals created a nice buffer for the IC and rad up against the front panel
All of which got me to the point where I needed to pull the engine from the test car for the last time. I made some measurements for a removable lower IC/rad support, which will allow me to slide the engine & box forwards on their mounts in order to access the bell housing bolts.
Having already flared one transmission tunnel to test fit the Nissan 6 Speed box, I made quick work of it the 2nd time around.
I offered the CD009 trans up into its new home for the first time. I'll eventually sit about 3-4" further back than this.
I've made a shifter that'll relocate the Nissan output to the stock e30 location. I'm hoping it'll work out and that I'll retain all of the stock interior trim.
I also had to address this big ole thing (brake servo/booster)
The engine simply won't fit with it, so I'm opting for the tried and tested e30 track spec braking system, which is a booster-less setup. With the correct master cylinder bore the stiffness of the pedal can be appropriately reduced. I'm going with a 19mm front and rear master cylinder.
To delete the booster, relocate the master cylinder and alter the pivot point, I did the following..
(Reinforced one side to cope any tendency to flex/twist)
Steel brace between the web
Slapped together with a new return spring location
All cleaned up and installed. This moves everything safely out of the way of the intake manifold.
That's as far as I had gotten before heading home to Ireland for 10 Days. While there, I smuggled back 2 of my 4 16x9J Schmidt Modernlines.
I've always liked how these looked on my old e30.
That's how things currently sit. This weekend I plan on dropping the engine in and routing the external wastegate and screamer pipe.
My aim is to have the thing driving by Nov 1st. We'll see.
Wed Sep 19, 2018 12:46 pm
Users browsing this forum: No registered users and 1 guest
cron
